Surfaces of genus $g\ge 1$ in 3D contact sub-Riemannian manifolds
We consider smooth embedded surfaces in a 3D contact sub-Riemannian manifold and the problem of the finiteness of the induced distance ( i.e. , the infimum of the length of horizontal curves that belong to the surface). Recently it has been proved that for a surface having the topology of a sphere embedded in a tight co-orientable structure, the distance is always finite. In this paper we study closed surfaces of genus larger than 1, proving that such surfaces can be embedded in such a way that the induced distance is finite or infinite. We then study the structural stability of the fmiteness/not-finiteness of the distance.
Mathématiques [math]
