Surfaces of genus $g\ge 1$ in 3D contact sub-Riemannian manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2023
We consider smooth embedded surfaces in a 3D contact sub-Riemannian manifold and the problem of the finiteness of the induced distance ( i.e. , the infimum of the length of horizontal curves that belong to the surface). Recently it has been proved that for a surface having the topology of a sphere embedded in a tight co-orientable structure, the distance is always finite. In this paper we study closed surfaces of genus larger than 1, proving that such surfaces can be embedded in such a way that the induced distance is finite or infinite. We then study the structural stability of the fmiteness/not-finiteness of the distance.
2305.03373.pdf (2.05 Mo) Télécharger le fichier
hal-04307729 , version 1 (26-11-2023)
Ugo Boscain, Eugenio Bellini. Surfaces of genus $g\ge 1$ in 3D contact sub-Riemannian manifolds. ESAIM: Control, Optimisation and Calculus of Variations, 2023, 29, pp.79. ⟨10.1051/cocv/2023072⟩. ⟨hal-04307729⟩
22 Consultations
12 Téléchargements
