Augmented SPDNet: Second-Order Neural Network for Motor Imagery-Based BCI - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Poster Communications Year : 2023
Brain Computer Interfaces (BCI) can be defined as a technology that measures brain activity and translates it into instructions for a digital system. We will focus on non-invasive (EEG)-based BCI (BCI-EEG). Let us consider a typical EEG signal after preprocessing. In the figure on the left, we show an EEG signal measured with 4 different electrodes. Our work will be focused on Motor Imagery (MI) BCI, so we want to understand if the subject, for example, is thinking about moving the left or the right hand.
SophiaSummit2023_FINAL.pdf (1.42 Mo) Télécharger le fichier
Dates and versions
hal-04308549 , version 1 (27-11-2023)
Attribution
Identifiers
  • HAL Id : hal-04308549 , version 1
Cite
Igor Carrara, Bruno Aristimunha, Marie-Constance Corsi, Raphael Yokoingawa De Camargo, Sylvain Chevallier, et al.. Augmented SPDNet: Second-Order Neural Network for Motor Imagery-Based BCI. Soph.IA summit 2023, Nov 2023, Sophia Antipolis, France. ⟨hal-04308549⟩
88 View
55 Download
Share
