On ISS with respect to average value of disturbances: a time-delay approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2023
Emilia Fridman
  • Fonction : Auteur
  • PersonId : 838164
For input-affine nonlinear dynamical systems, an input-to-state stability analysis with respect to (weighted) average values of exogenous perturbations is proposed. The time-delay method is used to represent the system in a suitable form for investigation: a kind of neutral-type differential equation. The introduced approach allows the asymptotic gains with respect to zero-mean periodic signals to be evaluated for nonlinear systems (an analogue of Bode magnitude plot), as well as for integral input-to-state stable systems with periodic inputs. The results are illustrated on the class of homogeneous systems.
Automatique
Aver_ISS.pdf (656.65 Ko) Télécharger le fichier
hal-04309870 , version 1 (27-11-2023)
Paternité
  • HAL Id : hal-04309870 , version 1
Denis Efimov, Emilia Fridman. On ISS with respect to average value of disturbances: a time-delay approach. IEEE Transactions on Automatic Control, In press. ⟨hal-04309870⟩
28 Consultations
73 Téléchargements
