Goal-Adaptive Meshing of Isogeometric Kirchhoff-Love Shells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Engineering with Computers Année : 2024
Mesh adaptivity is a technique to provide detail in numerical solutions without the need to refine the mesh over the whole domain. Mesh adaptivity in isogeometric analysis can be driven by Truncated Hierarchical B-splines (THB-splines) which add degrees of freedom locally based on finer B-spline bases. Labeling of elements for refinement is typically done using residual-based error estimators. In this paper, an adaptive meshing workflow for isogeometric Kirchhoff-Love shell analysis is developed. This framework includes THB-splines, mesh admissibility for combined refinement and coarsening and the Dual-Weighted Residual (DWR) method for computing element-wise error contributions. The DWR can be used in several structural analysis problems, allowing the user to specify a goal quantity of interest which is used to mark elements and refine the mesh. This goal functional can involve, for example, displacements, stresses, eigenfrequencies etc. The proposed framework is evaluated through a set of different benchmark problems, including modal analysis, buckling analysis and non-linear snap-through and bifurcation problems, showing high accuracy of the DWR estimator and efficient allocation of degrees of freedom for advanced shell computations.
Goal-Adaptive Meshing of Isogeometric Kirchhoff-Love Shells.pdf (13.42 Mo) Télécharger le fichier
Format : Figure, Image
hal-04313561 , version 1 (29-11-2023)
Hugo M. Verhelst, Angelos Mantzaflaris, Matthias M. Möller, J. den Besten. Goal-Adaptive Meshing of Isogeometric Kirchhoff-Love Shells. Engineering with Computers, 2024, ⟨10.1007/s00366-024-01958-4⟩. ⟨hal-04313561⟩
21 Consultations
8 Téléchargements
