Spectrum of the Dirichlet Laplacian in a thin cubic lattice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We give a description of the lower part of the spectrum of the Dirichlet Laplacian in an unbounded 3D periodic lattice made of thin bars (of width ε ≪ 1) which have a square cross section. This spectrum coincides with the union of segments which all go to +∞ as ε tends to zero due to the Dirichlet boundary condition. We show that the first spectral segment is extremely tight, of length O(e^{−δ/ε}), δ > 0, while the length of the next spectral segments is O(ε). To establish these results, we need to study in detail the properties of the Dirichlet Laplacian A^Ω in the geometry Ω obtained by zooming at the junction regions of the initial periodic lattice. This problem has its own interest and playing with symmetries together with max-min arguments as well as a well-chosen Friedrichs inequality, we prove that A^Ω has a unique eigenvalue in its discrete spectrum, which generates the first spectral segment. Additionally we show that there is no threshold resonance for A^Ω , that is no non trivial bounded solution at the threshold frequency for A^Ω. This implies that the correct 1D model of the lattice for the next spectral segments is a graph with Dirichlet conditions at the vertices. We also present numerics to complement the analysis.
ChNa23.pdf (715.61 Ko) Télécharger le fichier
hal-04314942 , version 1 (16-01-2023)
hal-04314942 , version 2 (29-11-2023)
  • HAL Id : hal-04314942 , version 1
Lucas Chesnel, Sergei A Nazarov. Spectrum of the Dirichlet Laplacian in a thin cubic lattice. 2023. ⟨hal-04314942v1⟩
45 Consultations
61 Téléchargements
