A global existence result for weakly coupled two-phase poromechanics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Multiphase poromechanics describes the evolution of multiphase flow in deformable porous media. Mathematical models for such multiphysics system are inheritely nonlinear, potentially degenerate and fully coupled systems of partial differential equations. In this work, we present a thermodynamically consistent multiphase poromechanics model falling into the category of Biot equations and obeying to a generalized gradient flow structure. It involves capillarity effects, degenerate relative permeabilities, and gravity effects. In addition to established models it introduces a Lagrange multiplier associated to a bound constraint on the effective porosity in particular ensuring its positivity. We establish existence of global weak solutions under the assumption of a weak coupling strength, implicitly utilizing the gradient flow structure, as well as regularization, a Faedo-Galerkin approach and compactness arguments. This comprises the first global existence result for multiphase poromechanics accounting for degeneracies that are consistent with the multiphase nature of the flow.
ExistencePoromechanics.pdf (512.33 Ko) Télécharger le fichier
hal-04316962 , version 1 (01-12-2023)
Jakub Wiktor Both, Clément Cancès. A global existence result for weakly coupled two-phase poromechanics. 2023. ⟨hal-04316962⟩
34 Consultations
25 Téléchargements
