Discrete Cosserat Static Model-Based Control of Soft Manipulator
In this paper, the continuous Cosserat static model is re-formulated by employing the piecewise linear strain (PLS) approach, which can obtain the analytic formula of the model to facilitate the controller design. The robust closed-loop control architecture based on the PLS Cosserat static model for the soft arm around its workspace is then established. To validate the performance of the proposed model-based control scheme, the point-to-point and time-varying trajectory tracking experiments under external disturbances have been conducted on the soft manipulator actuated by cables.
