Worst and average case hardness of decoding via smoothing bounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this work, we consider the worst and average case hardness of the decoding problems that are the basis for code-based cryptography. By a decoding problem, we consider inputs of the form (G, mG + t) for a matrix G that generates a code and a noise vector t, and the algorithm's goal is to recover m. We consider a natural strategy for creating a reduction to an average-case problem: from our input we simulate a Learning Parity with Noise (LPN) oracle, where we recall that LPN is essentially an average-case decoding problem where there is no a priori lower bound on the rate of the code. More formally, the oracle Ox outputs independent samples of the form ⟨x, a⟩+e, where a is a uniformly random vector and e is a noise bit. Such an approach is (implicit in) the previous worst-case to average-case reductions for coding problems (Brakerski et al Eurocrypt 2019, Yu and Zhang CRYPTO 2021). To analyze the effectiveness of this reduction, we use a smoothing bound derived recently by (Debris-Alazard et al IACR Eprint 2022), which quantifies the simulation error of this reduction. It is worth noting that this latter work crucially use a bound, known as the second linear programming bounds, on the weight distribution of the code generated here by G. Our approach, which is Fourier analytic in nature, applies to any smoothing distribution (so long as it is radial); for our purposes, the best choice appears to be Bernoulli (although for the analysis it is most effective to study the uniform distribution over a sphere, and subsequently translate the bound back to the Bernoulli distribution by applying a truncation trick). Our approach works naturally when reducing from a worst-case instance, as well as from an average-case instance. While we are unable to improve the parameters of the worst-case to average-case reductions of Brakerski et al or Yu and Zhang, we think that our work highlights two important points. Firstly, in analyzing the average-case to average-case reduction we run into inherent limitations of this reduction template. Essentially, it appears hopeless to reduce to an LPN instance for which the noise rate is more than inverse-polynomially biased away from uniform. We furthermore uncover a surprising weakness in the second linear programming bound: we observe that it is essentially useless for the regime of parameters where the rate of the code is inverse polynomial in the block-length. By highlighting these shortcomings, we hope to stimulate the development of new techniques for reductions between cryptographic decoding problems.
2022-1744.pdf (262.75 Ko) Télécharger le fichier
hal-04326764 , version 1 (06-12-2023)
Paternité
  • HAL Id : hal-04326764 , version 1
Thomas Debris-Alazard, Nicolas Resch. Worst and average case hardness of decoding via smoothing bounds. 2023. ⟨hal-04326764⟩
18 Consultations
33 Téléchargements
