Reduction from Sparse LPN to LPN, Dual Attack 3.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
The security of code-based cryptography relies primarily on the hardness of decoding generic linear codes. Until very recently, all the best algorithms for solving the decoding problem were information set decoders (ISD). However, recently a new algorithm called RLPNdecoding which relies on a completely different approach was introduced and it has been shown that RLPN outperforms significantly ISD decoders for a rather large range of rates. This RLPN decoder relies on two ingredients, first reducing decoding to some underlying LPN problem, and then computing efficiently many parity-checks of small weight when restricted to some positions. We revisit RLPN-decoding by noticing that, in this algorithm, decoding is in fact reduced to a sparse-LPN problem, namely with a secret whose Hamming weight is small. Our new approach consists this time in making an additional reduction from sparse-LPN to plain-LPN with a coding approach inspired by coded-BKW. It outperforms significantly the ISD's and RLPN for code rates smaller than 0.42. This algorithm can be viewed as the code-based cryptography cousin of recent dual attacks in lattice-based cryptography. We depart completely from the traditional analysis of this kind of algorithm which uses a certain number of independence assumptions that have been strongly questioned recently in the latter domain. We give instead a formula for the LPN noise relying on duality which allows to analyze the behavior of the algorithm by relying only on the analysis of a certain weight distribution. By using only a minimal assumption whose validity has been verified experimentally we are able to justify the correctness of our algorithm. This key tool, namely the duality formula, can be readily adapted to the lattice setting and is shown to give a simple explanation for some phenomena observed on dual attacks in lattices in [DP23b].
2023-1852.pdf (574.18 Ko) Télécharger le fichier
hal-04328262 , version 1 (07-12-2023)
Paternité
  • HAL Id : hal-04328262 , version 1
Kévin Carrier, Thomas Debris-Alazard, Charles Meyer-Hilfiger, Jean-Pierre Tillich. Reduction from Sparse LPN to LPN, Dual Attack 3.0. 2023. ⟨hal-04328262⟩
59 Consultations
15 Téléchargements
