Symbolic domains and reachability for nets with trajectories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This paper addresses the problem of reachability for timed models handling additional quantities progressing linearly such as distance of moving objects to a target. We first introduce a variant of Petri nets called trajectory nets where some places are standard control places containing tokens, and other places contain a simplified representation of trajectories of objects instead of tokens. We give a semantics for this model, and propose an abstraction of sets of equivalent configurations into symbolic domains. We show how to compute in polynomial time a symbolic representation of successors of configurations appearing in a domain, and prove that domains are closed under calculus of successors. Further, the set of domains for a fixed trajectory net is finite. When the control part of the model is bounded, reachability, coverability and safety properties involving distances can be checked in PSPACE on a sound, complete, and finite abstraction called a state class graph.
main.pdf (663.6 Ko) Télécharger le fichier
hal-04330097 , version 1 (07-12-2023)
Paternité
  • HAL Id : hal-04330097 , version 1
Loïc Hélouët, Prerak Contractor. Symbolic domains and reachability for nets with trajectories. 2023. ⟨hal-04330097⟩
37 Consultations
27 Téléchargements
