Study of the numerical method for an inverse problem of a simplified intestinal crypt - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this work we consider the study of an inverse problem for an intestinal crypt model. The original model is based on the interaction of epithelial cells with microbiota-derived chemicals diffusing in the crypt from the gut lumen. The 5 types of cells considered in the original model were reduced in this work to 3 types of cells for simplifications of the inverse problem. The inverse problem consists of determining the shape of the secretory cells of the deep crypt from observations of the stem cells and progenitor cells at a fixed time. The method used is the calculation of the adjoint state associated with the second-order BGK numerical scheme considered in [3], which allows calculating the critical points of the Lagrangian associated with the inverse problem, and applying a gradient method in order to minimize the cost function. The algorithm is described, and some numerical examples are given.
Proceeding_Sepulveda_MH_BL.pdf (1.11 Mo) Télécharger le fichier
hal-04332907 , version 1 (09-12-2023)
  • HAL Id : hal-04332907 , version 1
Marie Haghebaert, Béatrice Laroche, Mauricio A. Sepulveda Cortes. Study of the numerical method for an inverse problem of a simplified intestinal crypt. 2023. ⟨hal-04332907⟩
61 Consultations
10 Téléchargements
