Observing hidden neuronal states in experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We construct systematically experimental steady-state bifurcation diagrams for entorhinal cortex neurons. A slowly ramped voltage-clamp electrophysiology protocol serves as closed-loop feedback controlled experiment for the subsequent current-clamp open-loop protocol on the same cell. In this way, the voltage-clamped experiment determines dynamically stable and unstable (hidden) steady states of the current-clamp experiment. The transitions between observable steady states and observable spiking states in the current-clamp experiment reveal stability and bifurcations of the steady states, completing the steady-state bifurcation diagram.
hal-04333043 , version 1 (09-12-2023)
Dmitry Amakhin, Anton Chizhov, Guillaume Girier, Mathieu Desroches, Jan Sieber, et al.. Observing hidden neuronal states in experiments. 2023. ⟨hal-04333043⟩
14 Consultations
0 Téléchargements
