Memory and rejuvenation effects in spin glasses are governed by more than one length scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Physics Année : 2023
Luis Fernandez
Victor Martin-Mayor
Antonio Muñoz Sudupe
Ilaria Paga
Memory and rejuvenation effects in the magnetic response of off-equilibrium spin glasses have been widely regarded as the doorway into the experimental exploration of ultrametricity and temperature chaos. Unfortunately, despite more than twenty years of theoretical efforts following the experimental discovery of memory and rejuvenation, these effects have, thus far, been impossible to reliably simulate. Yet, three recent developments convinced us to accept this challenge: first, the custom-built Janus II supercomputer makes it possible to carry out simulations in which the very same quantities that can be measured in single crystals of CuMn are computed from the simulation, allowing for a parallel analysis of the simulation and experimental data. Second, Janus II simulations have taught us how numerical and experimental length scales should be compared. Third, we have recently understood how temperature chaos materializes in aging dynamics. All these three aspects have proved crucial for reliably reproducing rejuvenation and memory effects on the computer. Our analysis shows that at least three different length scales play a key role in aging dynamics, whereas essentially all the theoretical analyses of the aging dynamics emphasize the presence and crucial role of a single glassy correlation length.
2207.06207.pdf (15.7 Mo) Télécharger le fichier
hal-04341897 , version 1 (04-04-2024)
Paternité
Marco Baity-Jesi, Enrico Calore, Andrea Cruz, Luis Fernandez, José Miguel Gil-Narvion, et al.. Memory and rejuvenation effects in spin glasses are governed by more than one length scale. Nature Physics, 2023, 19 (7), pp.978-985. ⟨10.1038/s41567-023-02014-6⟩. ⟨hal-04341897⟩
31 Consultations
0 Téléchargements
