On the Minimum Number of Arcs in 4-Dicritical Oriented Graphs
We prove that every 4-dicritical oriented graph on n vertices has at least $(\frac{10}{3}+\frac{1}{51})n - 1$ arcs.
Mathématique discrète [cs.DM]
