An operator theoretical approach of some inverse problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
This work gives an overview of the solution to linear forward and inverse problems for a class of elliptic partial differential equations in two-dimensional domains Ω, in the framework of Banach spaces and operators. We focus on the equation ∇(σ∇u) = 0, with σ in Sobolev spaces W 1,p (Ω), 1 < p < ∞, with Dirichlet or Neumann or mixed boundary conditions. For domains Ω with Dini-smooth boundary ∂Ω, the approach is based on the properties of generalized Hardy spaces.
Survey_Oct_2022.pdf (294.04 Ko) Télécharger le fichier
hal-04355468 , version 1 (20-12-2023)
Paternité
Juliette Leblond, Elodie Pozzi. An operator theoretical approach of some inverse problems. Ilia Binder; Damir Kinzebulatov; Javad Mashreghi. Function Spaces, Theory and Applications, Springer, In press, Fields Institute Communications ; vol 87, 978-3-031-39272-6. ⟨10.1007/978-3-031-39270-2_3⟩. ⟨hal-04355468⟩
66 Consultations
68 Téléchargements
