Variable importance in high-dimensional settings requires grouping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Explaining the decision process of machine learning algorithms is nowadays crucial for both model's performance enhancement and human comprehension. This can be achieved by assessing the variable importance of single variables, even for high-capacity non-linear methods, e.g. Deep Neural Networks (DNNs). While only removal-based approaches, such as Permutation Importance (PI), can bring statistical validity, they return misleading results when variables are correlated. Conditional Permutation Importance (CPI) bypasses PI's limitations in such cases. However, in high-dimensional settings, where high correlations between the variables cancel their conditional importance, the use of CPI as well as other methods leads to unreliable results, besides prohibitive computation costs. Grouping variables statistically via clustering or some prior knowledge gains some power back and leads to better interpretations. In this work, we introduce BCPI (Block-Based Conditional Permutation Importance), a new generic framework for variable importance computation with statistical guarantees handling both single and group cases. Furthermore, as handling groups with high cardinality (such as a set of observations of a given modality) are both time-consuming and resource-intensive, we also introduce a new stacking approach extending the DNN architecture with sub-linear layers adapted to the group structure. We show that the ensuing approach extended with stacking controls the type-I error even with highly-correlated groups and shows top accuracy across benchmarks. Furthermore, we perform a real-world data analysis in a large-scale medical dataset where we aim to show the consistency between our results and the literature for a biomarker prediction.
AAAI_proceedings_Arxiv.pdf (1.54 Mo) Télécharger le fichier
hal-04356917 , version 1 (20-12-2023)
Paternité
Ahmad Chamma, Bertrand Thirion, Denis Engemann. Variable importance in high-dimensional settings requires grouping. AAAI 2024 - The 38th Annual AAAI Conference on Artificial Intelligence, Feb 2024, Vancouver, Canada. ⟨hal-04356917⟩
52 Consultations
24 Téléchargements
