Correlated Structures in a Balanced Motion Interacting with an Internal Wave - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Abstract Characterizing the loss of coherence of an internal tide propagating through mesoscale turbulence has been a major challenge in oceanography, particularly due to its implications for the interpretation of satellite data. In this paper, we intend to study the correlations between a balanced motion and the incoherent part of a wave in an idealised configuration. We introduce a new modal decomposition technique, named broad-band proper orthogonal decomposition (BBPOD), which consists in performing a proper orthogonal decomposition (POD) on complex demodulated variables. After connecting BBPOD to the standard SPOD, we show that BBPOD, coupled with the extended POD technique enables us to associate the principal components of the incoherent field to the slow flow structures responsible of this loss of coherence through triadic interactions with the incident wave.
STUOD_proceedings_Igor.pdf (4.55 Mo) Télécharger le fichier
hal-04357375 , version 1 (21-12-2023)
Paternité
Igor Maingonnat, Gilles Tissot, Noé Lahaye. Correlated Structures in a Balanced Motion Interacting with an Internal Wave. STUOD 2022 - Stochastic Transport in Upper Ocean Dynamics Annual Workshop, Sep 2022, Londres, United Kingdom. pp.207-222, ⟨10.1007/978-3-031-40094-0_9⟩. ⟨hal-04357375⟩
100 Consultations
6 Téléchargements
