Surface Roughness in RANS Applied to Aircraft Ice Accretion Simulation: A Review - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fluids Année : 2023
Experimental and numerical fluid dynamics studies highlight a change of flow structure in the presence of surface roughness. The changes involve both wall heat transfer and skin friction, and are mainly restricted to the inner region of the boundary layer. Aircraft in-flight icing is a typical application where rough surfaces play an important role in the airflow structure and the subsequent ice growth. The objective of this work is to investigate how surface roughness is tackled in RANS with wall resolved boundary layers for aeronautics applications, with a focus on ice-induced roughness. The literature review shows that semi-empirical correlations were calibrated on experimental data to model flow changes in the presence of roughness. The correlations for RANS do not explicitly resolve the individual roughness. They principally involve turbulence model modifications to account for changes in the velocity and temperature profiles in the near-wall region. The equivalent sand grain roughness (ESGR) approach emerges as a popular metric to characterize roughness and is employed as a length scale for the RANS model. For in-flight icing, correlations were developed, accounting for both surface geometry and atmospheric conditions. Despite these research efforts, uncertainties are present in some specific conditions, where space and time roughness variations make the simulations difficult to calibrate. Research that addresses this gap could help improve ice accretion predictions.
fluids-08-00278-1.pdf (3.14 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-04359324 , version 1 (21-12-2023)
Paternité
Kevin Ignatowicz, François Morency, Heloise Beaugendre. Surface Roughness in RANS Applied to Aircraft Ice Accretion Simulation: A Review. Fluids, 2023, 8 (10), pp.278. ⟨10.3390/fluids8100278⟩. ⟨hal-04359324⟩
13 Consultations
7 Téléchargements
