Investigation of the effects of Cowling approximation on adiabatic wave propagation in helioseismology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
Helioseismology investigates the interior structures and the dynamics of the Sun from oscillations observed on its visible surface. Ignoring flow and rotation, time-harmonic adiabatic waves in a selfgravitating Sun in Eulerian-Lagrangian description are described by the Lagrangian displacement ξ and the gravitational potential perturbation δ ϕ which satisfy Galbrun's equation [1] coupled with a Poisson equation. In most works, perturbation to gravitational potential δ ϕ is neglected under Cowling's approximation [3]. However, this approximation is known to shift the eigenvalues of the forward operator for low-order harmonic modes [4]. Here, we study the effects of this approximation on numerical solutions and discuss its implication for the inverse problem. Removing Cowling's approximation allows us to accurately simulate waves for low-degree modes, and help us better characterize the deep interior of the Sun. The investigation is carried out for a Sun with minimum activity, called quiet Sun, whose background coefficients are given by the radially symmetric standard solar model Model S in the interior, with a choice of extension beyond the surface to include the presence of atmosphere cf [5]. Radial symmetry is exploited to decouple the problem on each spherical harmonic mode ℓ to give a system of ordinary differential equations in radial variable. This extends previous work [1] which employed Cowling approximation. The modal system is resolved by using the Hybridizable Discontinuous Galerkin method (HDG). For purpose of validation, the equations are coupled with free-surface boundary condition which is adapted for low-frequency modes and is commonly employed in helioseismology cf. [6]. Since eigenvalues are poles of Green's tensor, the magnitude of the latter as a function of frequency peaks around an eigenvalue. As preliminary results, we compare the location where the Green's tensor peaks to the values of eigenvalues computed by the GYRE code [2], between which we find a good agreement.
Abstract_AIP_2023.pdf (136.96 Ko) Télécharger le fichier
hal-04359755 , version 1 (21-12-2023)
Paternité
  • HAL Id : hal-04359755 , version 1
Hélène Barucq, Lola Chabat, Florian Faucher, Damien Fournier, Ha Pham. Investigation of the effects of Cowling approximation on adiabatic wave propagation in helioseismology. AIP 2023 - 11th Applied Inverse Problems, Sep 2023, Gottingen, Germany. 2023. ⟨hal-04359755⟩
37 Consultations
13 Téléchargements
