Linear quadratic optimal control turnpike in finite and infinite dimension: two-term expansion of the value function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2024
In this paper, we consider a linear quadratic (LQ) optimal control problem in both finite and infinite dimensions. We derive an asymptotic expansion of the value function as the fixed time horizon T tends to infinity. The leading term in this expansion, proportional to T, corresponds to the optimal value attained through the classical turnpike theory in the associated static problem. The remaining terms are associated with optimal stabilization problems towards the turnpike.
turnpike_LQ.pdf (374.68 Ko) Télécharger le fichier
hal-04361557 , version 1 (22-12-2023)
Veljko Askovic, Emmanuel Trélat, Hasnaa Zidani. Linear quadratic optimal control turnpike in finite and infinite dimension: two-term expansion of the value function. Systems and Control Letters, 2024, 188, pp.105803. ⟨hal-04361557⟩
17 Consultations
11 Téléchargements
