Genomic loci influence patterns of structural covariance in the human brain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the National Academy of Sciences of the United States of America Année : 2023
Junhao Wen
  • Fonction : Auteur
  • PersonId : 1329664
Normal and pathologic neurobiological processes influence brain morphology in coordinated ways that give rise to patterns of structural covariance (PSC) across brain regions and individuals during brain aging and diseases. The genetic underpinnings of these patterns remain largely unknown. We apply a stochastic multivariate factorization method to a diverse population of 50,699 individuals (12 studies and 130 sites) and derive data-driven, multi-scale PSCs of regional brain size. PSCs were significantly correlated with 915 genomic loci in the discovery set, 617 of which are newly identified, and 72% were independently replicated. Key pathways influencing PSCs involve reelin signaling, apoptosis, neurogenesis, and appendage development, while pathways of breast cancer indicate potential interplays between brain metastasis and PSCs associated with neurodegeneration and dementia. Using support vector machines, multi-scale PSCs effectively derive imaging signatures of several brain diseases. Our results elucidate genetic and biological underpinnings that influence structural covariance patterns in the human brain.
Wen_PSC_main.pdf (15.42 Mo) Télécharger le fichier
Wen_PSC_SI.pdf (6.21 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04362321 , version 1 (22-12-2023)
Junhao Wen, Ilya M Nasrallah, Ahmed Abdulkadir, Theodore D Satterthwaite, Zhijian Yang, et al.. Genomic loci influence patterns of structural covariance in the human brain. Proceedings of the National Academy of Sciences of the United States of America, 2023, 120 (52), ⟨10.1073/pnas.2300842120⟩. ⟨hal-04362321⟩
74 Consultations
38 Téléchargements
