L-C2ST: Local Diagnostics for Posterior Approximations in Simulation-Based Inference - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many recent works in simulation-based inference (SBI) rely on deep generative models to approximate complex, high-dimensional posterior distributions. However, evaluating whether or not these approximations can be trusted remains a challenge. Most approaches evaluate the posterior estimator only in expectation over the observation space. This limits their interpretability and is not sufficient to identify for which observations the approximation can be trusted or should be improved. Building upon the well-known classifier two-sample test (C2ST), we introduce L-C2ST, a new method that allows for a local evaluation of the posterior estimator at any given observation. It offers theoretically grounded and easy to interpret -- e.g. graphical -- diagnostics, and unlike C2ST, does not require access to samples from the true posterior. In the case of normalizing flow-based posterior estimators, L-C2ST can be specialized to offer better statistical power, while being computationally more efficient. On standard SBI benchmarks, L-C2ST provides comparable results to C2ST and outperforms alternative local approaches such as coverage tests based on highest predictive density (HPD). We further highlight the importance of local evaluation and the benefit of interpretability of L-C2ST on a challenging application from computational neuroscience.
2306.03580.pdf (6.68 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04363348 , version 1 (24-12-2023)
Paternité
Julia Linhart, Alexandre Gramfort, Pedro L C Rodrigues. L-C2ST: Local Diagnostics for Posterior Approximations in Simulation-Based Inference. NeurIPS 2023 - 37th Conference on Neural Information Processing Systems, Dec 2023, New Orleans (LA), United States. pp.1-27, ⟨10.48550/arXiv.2306.03580⟩. ⟨hal-04363348⟩
37 Consultations
17 Téléchargements
