Quadratic programming with ramp functions and fast online QP-MPC solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2023
A novel method is proposed for solving quadratic programming problems arising in model predictive control. The method is based on an implicit representation of the Karush-Kuhn-Tucker conditions using ramp functions. The method is shown to be highly efficient on both small and fairly large Quadratic Program problems, can be implemented using simple computer code, and has modest memory requirements.
MPC_ramp_functions_v2 (1).pdf (370.81 Ko) Télécharger le fichier
hal-04363951 , version 1 (26-12-2023)
Giorgio Valmorbida, Morten Hovd. Quadratic programming with ramp functions and fast online QP-MPC solutions. Automatica, 2023, 153, pp.111011. ⟨10.1016/j.automatica.2023.111011⟩. ⟨hal-04363951⟩
26 Consultations
34 Téléchargements
