Robust stability analysis of continuous PWA systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper studies the robust stability of the origin of continuous-time Piecewise Affine (PWA) systems. We consider an implicit representation based on vector-valued ramp functions to model PWA continuous-time systems. From this representation, we derive Linear Matrix Inequality (LMI) stability conditions suitable to deal with polytopic uncertainties that can modify both the dynamics and the regions of the state-space partition of the PWA system. Two numerical examples illustrate the effectiveness of the proposed conditions.
1-s2.0-S2405896323020359-main.pdf (762.17 Ko) Télécharger le fichier
hal-04363976 , version 1 (26-12-2023)
Leonardo Cabral, Giorgio Valmorbida, João Manoel Gomes da Silva. Robust stability analysis of continuous PWA systems. 22nd World Congress of the International Federation of Automatic Control (IFAC 2023), Ifac, Jul 2023, Yokohama, Japan. pp.556-561, ⟨10.1016/j.ifacol.2023.10.1626⟩. ⟨hal-04363976⟩
30 Consultations
11 Téléchargements
