Constructing phylogenetic networks via cherry picking and machine learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms for Molecular Biology Année : 2023
Background Combining a set of phylogenetic trees into a single phylogenetic network that explains all of them is a fundamental challenge in evolutionary studies. Existing methods are computationally expensive and can either handle only small numbers of phylogenetic trees or are limited to severely restricted classes of networks. Results In this paper, we apply the recently-introduced theoretical framework of cherry picking to design a class of efficient heuristics that are guaranteed to produce a network containing each of the input trees, for practical-size datasets consisting of binary trees. Some of the heuristics in this framework are based on the design and training of a machine learning model that captures essential information on the structure of the input trees and guides the algorithms towards better solutions. We also propose simple and fast randomised heuristics that prove to be very effective when run multiple times. Conclusions Unlike the existing exact methods, our heuristics are applicable to datasets of practical size, and the experimental study we conducted on both simulated and real data shows that these solutions are qualitatively good, always within some small constant factor from the optimum. Moreover, our machine-learned heuristics are one of the first applications of machine learning to phylogenetics and show its promise.
33356.pdf (5.35 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-04365666 , version 1 (28-12-2023)
Paternité
Giulia Bernardini, Leo van Iersel, Esther Julien, Leen Stougie. Constructing phylogenetic networks via cherry picking and machine learning. Algorithms for Molecular Biology, 2023, 18, ⟨10.1186/s13015-023-00233-3⟩. ⟨hal-04365666⟩
7 Consultations
12 Téléchargements
