Time-varying Signals Recovery via Graph Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The recovery of time-varying graph signals is a fundamental problem with numerous applications in sensor networks and forecasting in time series. Effectively capturing the spatio-temporal information in these signals is essential for the downstream tasks. Previous studies have used the smoothness of the temporal differences of such graph signals as an initial assumption. Nevertheless, this smoothness assumption could result in a degradation of performance in the corresponding application when the prior does not hold. In this work, we relax the requirement of this hypothesis by including a learning module. We propose a Time Graph Neural Network (TimeGNN) for the recovery of time-varying graph signals. Our algorithm uses an encoder-decoder architecture with a specialized loss composed of a mean squared error function and a Sobolev smoothness operator.TimeGNN shows competitive performance against previous methods in real datasets.
2302.11313 (4).pdf (1.05 Mo) Télécharger le fichier
hal-04368767 , version 1 (01-01-2024)
John A Castro-Correa, Jhony H Giraldo, Anindya Mondal, Mohsen Badiey, Thierry Bouwmans, et al.. Time-varying Signals Recovery via Graph Neural Networks. ICASSP 2023 - IEEE International Conference on Acoustics, Speech and Signal Processing, Jun 2023, Rhodes Island, Greece. pp.1-5, ⟨10.1109/ICASSP49357.2023.10096168⟩. ⟨hal-04368767⟩
56 Consultations
14 Téléchargements
