Arbitrary High Order WENO Finite Volume Scheme with Flux Globalization for Moving Equilibria Preservation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In the context of preserving stationary states, e.g. lake at rest and moving equilibria, a new formulation of the shallow water system, called Flux Globalization has been introduced by Cheng et al. (2019). This approach consists in including the integral of the source term in the global flux and reconstructing the new global flux rather than the conservative variables. The resulting scheme is able to preserve a large family of smooth and discontinuous steady state moving equilibria. In this work, we focus on an arbitrary high order WENO Finite Volume (FV) generalization of the global flux approach. The most delicate aspect of the algorithm is the appropriate definition of the source flux (integral of the source term) and the quadrature strategy used to match it with the WENO reconstruction of the hyperbolic flux. When this construction is correctly done, one can show that the resulting WENO FV scheme admits exact discrete steady states characterized by constant global fluxes. We also show that, by an appropriate quadrature strategy for the source, we can embed exactly some particular steady states, e.g. the lake at rest for the shallow water equations. It can be shown that an exact approximation of global fluxes leads to a scheme with better convergence properties and improved solutions. The novel method has been tested and validated on classical cases: subcritical, supercritical and transcritical flows.
view_arxiv.pdf (337.58 Ko) Télécharger le fichier
hal-04372541 , version 1 (11-12-2022)
hal-04372541 , version 2 (04-01-2024)
Mirco Ciallella, Davide Torlo, Mario Ricchiuto. Arbitrary High Order WENO Finite Volume Scheme with Flux Globalization for Moving Equilibria Preservation. 2022. ⟨hal-04372541v1⟩
91 Consultations
53 Téléchargements
