Stability analysis of two-class retrial systems with constant retrial rates and general service times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Performance Evaluation Année : 2023
We establish stability criterion for a two-class retrial system with Poisson inputs, general class-dependent service times and class-dependent constant retrial rates. We also characterise an interesting phenomenon of partial stability when one orbit is tight but the other orbit goes to infinity in probability. All theoretical results are illustrated by numerical experiments.
PEVA_Retrial_TwoClass_2023.pdf (1.54 Mo) Télécharger le fichier
hal-04372687 , version 1 (04-01-2024)
Paternité
Konstantin Avrachenkov, Evsey Morozov, Ruslana Nekrasova. Stability analysis of two-class retrial systems with constant retrial rates and general service times. Performance Evaluation, 2023, 159, pp.102330. ⟨10.1016/j.peva.2022.102330⟩. ⟨hal-04372687⟩
15 Consultations
4 Téléchargements
