Codeplay: Autotelic Learning through Collaborative Self-Play in Programming Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autotelic learning is the training setup where agents learn by setting their own goals and trying to achieve them. However, creatively generating freeform goals is challenging for autotelic agents. We present Codeplay, an algorithm casting autotelic learning as a game between a Setter agent and a Solver agent, where the Setter generates programming puzzles of appropriate difficulty and novelty for the solver and the Solver learns to achieve them. Early experiments with the Setter demonstrates one can effectively control the tradeoff between difficulty of a puzzle and its novelty by tuning the reward of the Setter, a code language model finetuned with deep reinforcement learning.
_IMOL_Neurips2023__Codeplay-1.pdf (2.49 Mo) Télécharger le fichier
hal-04374993 , version 1 (05-01-2024)
  • HAL Id : hal-04374993 , version 1
Laetitia Teodorescu, Cédric Colas, Matthew Bowers, Thomas Carta, Pierre-Yves Oudeyer. Codeplay: Autotelic Learning through Collaborative Self-Play in Programming Environments. IMOL 2023 - Intrinsically Motivated Open-ended Learning workshop at NeurIPS 2023, Dec 2023, New Orleans, United States. ⟨hal-04374993⟩
Collections
INRIA INRIA2
38 Consultations
40 Téléchargements
