Minimum number of arcs in $k$-critical digraphs with order at most $2k-1$ - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... (Preprint) Year : 2023
The dichromatic number $\vec{\chi}(D)$ of a digraph $D$ is the least integer $k$ for which $D$ has a coloring with $k$ colors such that there is no monochromatic directed cycle in $D$. The digraphs considered here are finite and may have antiparallel arcs, but no parallel arcs. A digraph $D$ is called $k$-critical if each proper subdigraph $D'$ of $D$ satisfies $\vec{\chi}(D')<\vec{\chi}(D)=k$. For integers $k$ and $n$, let $\overrightarrow{\mathrm{ext}}(k,n)$ denote the minimum number of arcs possible in a $k$-critical digraph of order $n$. It is easy to show that $\overrightarrow{\mathrm{ext}}(2,n)=n$ for all $n\geq 2$, and $\overrightarrow{\mathrm{ext}}(3,n)\geq 2n$ for all possible $n$, where equality holds if and only if $n$ is odd and $n\geq 3$. As a main result we prove that if $n, k$ and $p$ are integers with $n=k+p$ and $2\leq p \leq k-1$, then $\overrightarrow{\mathrm{ext}}(k,n)=2({\binom{n}{2}} - (p^2+1))$, and we give an exact characterisation of $k$-critical digraphs for which equality holds. This generalizes a result about critical graphs obtained in 1963 by Tibor Gallai.
Dates and versions
hal-04379883 , version 1 (08-01-2024)
Attribution
Identifiers
Cite
Lucas Picasarri-Arrieta, Michael Stiebitz. Minimum number of arcs in $k$-critical digraphs with order at most $2k-1$. 2023. ⟨hal-04379883⟩
5 View
0 Download
Share
