Non-Parametric Learning of Stochastic Differential Equations with Fast Rates of Convergence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We propose a novel non-parametric learning paradigm for the identification of drift and diffusion coefficients of non-linear stochastic differential equations, which relies upon discretetime observations of the state. The key idea essentially consists of fitting a RKHS-based approximation of the corresponding Fokker-Planck equation to such observations, yielding theoretical estimates of learning rates which, unlike previous works, become increasingly tighter when the regularity of the unknown drift and diffusion coefficients becomes higher. Our method being kernel-based, offline pre-processing may in principle be profitably leveraged to enable efficient numerical implementation.
2305.15557.pdf (518.48 Ko) Télécharger le fichier
hal-04381810 , version 1 (09-01-2024)
Riccardo Bonalli, Alessandro Rudi. Non-Parametric Learning of Stochastic Differential Equations with Fast Rates of Convergence. 2024. ⟨hal-04381810⟩
26 Consultations
12 Téléchargements
