A Survey of Designs for Combined 2D+3D Visual Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2024
We examine visual representations of data that make use of combinations of both 2D and 3D data mappings. Combining 2D and 3D representations is a common technique that allows viewers to understand multiple facets of the data with which they are interacting. While 3D representations focus on the spatial character of the data or the dedicated 3D data mapping, 2D representations often show abstract data properties and take advantage of the unique benefits of mapping to a plane. Many systems have used unique combinations of both types of data mappings effectively. Yet there are no systematic reviews of the methods in linking 2D and 3D representations. We systematically survey the relationships between 2D and 3D visual representations in major visualization publications---IEEE VIS, IEEE TVCG, and EuroVis---from 2012 to 2022. We closely examined 105 papers where 2D and 3D representations are connected visually, interactively, or through animation. These approaches are designed based on their visual environment, the relationships between their visual representations, and their possible layouts. Through our analysis, we introduce a design space as well as provide design guidelines for effectively linking 2D and 3D visual representations.
Hong_2024_SDC.pdf (137.51 Mo) Télécharger le fichier
Format : Figure, Image
Licence : CC BY - Paternité
hal-04382271 , version 1 (09-01-2024)
Copyright (Tous droits réservés)
Jiayi Hong, Rostyslav Hnatyshyn, Ebrar A. D. Santos, Ross Maciejewski, Tobias Isenberg. A Survey of Designs for Combined 2D+3D Visual Representations. IEEE Transactions on Visualization and Computer Graphics, In press, ⟨10.1109/TVCG.2024.3388516⟩. ⟨hal-04382271⟩
111 Consultations
5 Téléchargements
