Approximation diffusion for the nonlinear Schrödinger equation with a random potential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2024
We prove that the stochastic Nonlinear Schrödinger (NLS) equation is the limit of NLS equation with random potential with vanishing correlation length. We generalize the perturbed test function method to the context of dispersive equations. Apart from the difficulty of working in infinite dimension, we treat the case of random perturbations which are not assumed uniformly bounded.
ApproximationDiffusionNLS_revised.pdf (619.33 Ko) Télécharger le fichier
hal-04383170 , version 1 (09-01-2024)
Paternité
Grégoire Barrué, Arnaud Debussche, Maxime Tusseau. Approximation diffusion for the nonlinear Schrödinger equation with a random potential. Asymptotic Analysis, In press, pp.1-42. ⟨10.3233/asy-241894⟩. ⟨hal-04383170⟩
58 Consultations
39 Téléchargements
