Second order perturbation theory of two-scale systems in fluid dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In the present paper we study slow-fast systems of coupled equations from fluid dynamics, where the fast component is perturbed by additive noise. We prove that, under a suitable limit of infinite separation of scales, the slow component of the system converges in law to a solution of the initial equation perturbed with transport noise, and subject to the influence of an additional Itō-Stokes drift. The obtained limit equation is very similar to turbulent models derived heuristically. Our results apply to the Navier-Stokes equations in dimension $d=2,3$; the Surface Quasi-Geostrophic equations in dimension $d=2$; and the Primitive equations in dimension $d=2,3$.
Fichier non déposé
hal-04383854 , version 1 (09-01-2024)
Paternité
Arnaud Debussche, Umberto Pappalettera. Second order perturbation theory of two-scale systems in fluid dynamics. 2024. ⟨hal-04383854⟩
23 Consultations
0 Téléchargements
