Optimal cell behavior in time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
Dafni Giannari
  • Fonction : Auteur
Diego A Oyarzún
  • Fonction : Auteur
Steffen Waldherr
  • Fonction : Auteur
Agustín G Yabo
  • Fonction : Auteur
This is a chapter from the free textbook "Economic Principles in Cell Biology"
Microorganisms live in continually changing environments, which require them to develop adaptation strategies. These strategies have been profitably studied under the assumption that microorganisms have evolved to optimize one or several aspects of their adaptive response. The mathematical formalization of this assumption leads to dynamic optimization problems that can be solved by means of techniques from optimal control theory. The chapter discusses three example problems: dynamic optimization of enzyme expression in metabolic pathways, dynamic optimization of coarse-grained models of cellular growth, and dynamic flux balance analysis. The results obtained for these problems illustrate the interest of studying adaptation strategies from the perspective of dynamic optimization, and the strengths and weaknesses of this approach.
chapter-TIM-preprint.pdf (941.09 Ko) Télécharger le fichier
hal-04383880 , version 1 (05-04-2024)
Paternité
Hidde de Jong, Dafni Giannari, Diego A Oyarzún, Steffen Waldherr, Agustín G Yabo. Optimal cell behavior in time. Economic Principles in Cell Biology, Zenodo, 2023, ⟨10.5281/zenodo.8157066⟩. ⟨hal-04383880⟩
25 Consultations
1 Téléchargements
