Exponential stabilizability and observability at the target imply semiglobal exponential stabilizability by templated output feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
For nonlinear analytic control systems, we introduce a new paradigm for dynamic output feedback stabilization. We propose to periodically sample the usual observer based control law, and to reshape it so that it coincides with a "control template" on each time period. By choosing a control template making the system observable, we prove that this method allows to bypass the uniform observability assumption that is used in most nonlinear separation principles. We prove the genericity of control templates by adapting a universality theorem of Sussmann.
templated_controls.pdf (554.49 Ko) Télécharger le fichier
hal-04387614 , version 1 (11-01-2024)
Vincent Andrieu, Lucas Brivadis, Jean-Paul Gauthier, Ludovic Sacchelli, Ulysse Serres. Exponential stabilizability and observability at the target imply semiglobal exponential stabilizability by templated output feedback. 2024. ⟨hal-04387614⟩
56 Consultations
14 Téléchargements
