Event-Driven FaaS Workflows for Enabling IoT Data Processing at the Cloud Edge Continuum
Continuum Computing encompasses the integration of diverse infrastructures, including cloud, edge, and fog, to facilitate seamless migration of applications based on their specific needs, ensuring optimal satisfaction of their requirements. The primary obstacles in this particular context mostly pertain to the incapacity to promptly respond to changes in the environment or the quality of service (QoS) constraints of the application, as well as the incapability to maintain an application in a stateless manner, hence impeding its relocation without the risk of data loss. The objective of this research is to tackle the aforementioned issues through the introduction of a framework based on Function-as-a-Service (FaaS) and event-driven architecture. This framework enables the decomposition, localization, and relocation of applications inside a Continuum infrastructure, facilitated by a rule engine that is both system and data-aware.
