Data assimilation to quantify and reduce uncertainty in ecohydrology modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Physically-based models represent detailed surface/subsurface transfer, but the required spatial information does not allow their operational use. In situ data on pesticides in a catchment are usually rare and not continuous in time and space. Satellite images, on the other hand, well describe data in space, but only water related, and at limited time frequency. In my studies, I aim to exploit these 3 types of information (model, in situ data, images) with adapted data assimilation methods, in order to improve pesticide and hydrological parameters, and quantify and reduce the simulations uncertainties. This seminary will discuss the methods and results from several studies developed in the RIVERLY unit (INRAE Lyon), from hydroclimatology to ecohydrology.
seminaire_ITES_AD_Lauvernet_13Nov2023.pdf (17.69 Mo) Télécharger le fichier
hal-04387935 , version 1 (11-01-2024)
Paternité
  • HAL Id : hal-04387935 , version 1
Claire Lauvernet, Emilie Rouzies, Arthur Vidard, Alexandre Devers, Jean-Philippe Vidal, et al.. Data assimilation to quantify and reduce uncertainty in ecohydrology modelling. Séminaire ITES 2023, ITES, Nov 2023, Strasbourg, France. ⟨hal-04387935⟩
35 Consultations
10 Téléchargements
