Learning canonical Potts models
The number of registered sequences of proteins grows much faster than the number of
experimentally annotated ones. A standard approach to mitigate this ever increasing gap is to
transfer annotations from a known sequence to other proteins of common ancestry called
homologs, which may have preserved similar structure and function. Doing so requires to identify
homologous sequences of a given query sequence, which is referred to as homology search. Many
methods have been proposed to retrieve homologs, from dynamic programming alignments to
more complex methods such as specific kinds of Hidden Markov models that are today’s
state-of-the-art for such task. However none of these approaches consider distant pairwise
dependencies of positions in the protein’s sequence. In parallel, recent works in another field
called contact prediction have shown promising results to identify 3D-contact points of a folded
protein. Such impulse was given thanks to global statistical models including Potts models, a
specific kind of Markov Random Fields that represents both positional information and
dependencies between pairs of positions in a sequence. Because of these properties, Potts models
have been adopted by Talibart during his thesis [20], hoping to identify remote homologs better
than current techniques by aligning these global models together. However, such task unveiled
new challenges. Because of their intrinsic overparametrization, and because of sampling biases
that could not be easily handled, the inferred models to be aligned are not comparable. Both
issues were studied during this internship hoping to make the whole alignment workflow fully
operational, first by searching for a relevant canonical form of Potts models to get rid of unwanted
parameters divergence, and then by working on the model inference itself by exploring how
explicit covariance-based methods that are able to overcome these sampling issues could be
adapted to directly infer comparable models.
