Exponential DG methods for Vlasov equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2024
In this work, an exponential Discontinuous Galerkin (DG) method is proposed to solve numerically Vlasov type equations. The DG method is used for space discretization which is combined exponential Lawson Runge-Kutta method for time discretization to get high order accuracy in time and space. In addition to get high order accuracy in time, the use of Lawson methods enables to overcome the stringent condition on the time step induced by the linear part of the system. Moreover, it can be proved that a discrete Poisson equation is preserved. Numerical results on Vlasov-Poisson and Vlasov Maxwell equations are presented to illustrate the good behavior of the exponential DG method.
exponential_DG.pdf (927.95 Ko) Télécharger le fichier
hal-04389308 , version 1 (11-01-2024)
Paternité
Nicolas Crouseilles, Xue Hong. Exponential DG methods for Vlasov equations. Journal of Computational Physics, 2024, 498, pp.1-38. ⟨10.1016/j.jcp.2023.112682⟩. ⟨hal-04389308⟩
21 Consultations
10 Téléchargements
