A toolkit for reliable benchmarking and research in multi-objective reinforcement learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multi-objective reinforcement learning algorithms (MORL) extend standard reinforcement learning (RL) to scenarios where agents must optimize multiple---potentially conflicting---objectives, each represented by a distinct reward function. To facilitate and accelerate research and benchmarking in multi-objective RL problems, we introduce a comprehensive collection of software libraries that includes: (i) MO-Gymnasium, an easy-to-use and flexible API enabling the rapid construction of novel MORL environments. It also includes more than 20 environments under this API. This allows researchers to effortlessly evaluate any algorithms on any existing domains; (ii) MORL-Baselines, a collection of reliable and efficient implementations of state-of-the-art MORL algorithms, designed to provide a solid foundation for advancing research. Notably, all algorithms are inherently compatible with MO-Gymnasium; and (iii) a thorough and robust set of benchmark results and comparisons of MORL-Baselines algorithms, tested across various challenging MO-Gymnasium environments. These benchmarks were constructed to serve as guidelines for the research community, underscoring the properties, advantages, and limitations of each particular state-of-the-art method.
Fichier non déposé
hal-04389594 , version 1 (11-01-2024)
  • HAL Id : hal-04389594 , version 1
Florian Felten, Alegre Lucas Nunes, Nowe Ann, Bazzan Ana L. C., Talbi El Ghazali, et al.. A toolkit for reliable benchmarking and research in multi-objective reinforcement learning. NeuriPS'2023 Thirty-seventh Annual Conference on Neural Information Processing Systems, Dec 2023, New Orleans (LA), United States. ⟨hal-04389594⟩
21 Consultations
0 Téléchargements
