An Integral Sliding-Mode-based Robust Interval Predictive Control for Perturbed Unicycle Mobile Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hector Ríos
  • Fonction : Auteur
  • PersonId : 969242
Manuel Mera
  • Fonction : Auteur
  • PersonId : 1244980
This paper contributes to the design of a robust control strategy for the trajectory tracking problem in perturbed unicycle mobile robots. The proposed strategy comprises the design of a robust control law, which is based on an Integral Sliding-Mode Control (ISMC) approach together with an interval predictor-based state-feedback controller and a Model Predictive Control (MPC) scheme. The robust controller deals with some perturbations in the kinematic model, and with state and input constraints that are related to restrictions on the workspace and saturated actuators, respectively. The proposed approach guarantees the exponential convergence to zero of the tracking error. Furthermore, the performance of the proposed approach is validated through some simulations.
Automatique
CDC23_1726_FI.pdf (555.41 Ko) Télécharger le fichier
hal-04390300 , version 1 (12-01-2024)
Paternité
  • HAL Id : hal-04390300 , version 1
Hector Ríos, Manuel Mera, Tarek Raïssi, Denis Efimov. An Integral Sliding-Mode-based Robust Interval Predictive Control for Perturbed Unicycle Mobile Robots. CDC 2023 - 62nd IEEE Conference on Decision and Control, Dec 2023, Singapore, Singapore. ⟨hal-04390300⟩
21 Consultations
13 Téléchargements
