Graph Matching improves the Similarity of Structural Brain Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
Structural parcellations are often built under the assumption of parcels' correspondences across patients. In the current work, we test the robustness of this hypothesis using graph matching strategies. Given a structural parcellation, we analyse a set of patients at different parcellation granularity (from 50 up to 1000 parcels). The aim of the analysis is to test via graph matching if the graphs obtained with a given parcellation should be considered as labelled or unlabelled. The results show a node correspondence for low resolution and the requirement of an unlabelled embedding for higher number of parcels. We showcase the graph matching results for the different parcellations as well as the importance of a correct geometrical embedding for unlabelled graphs to compute graph-valued statistics.
BrainMatching.pdf (8.66 Mo) Télécharger le fichier
hal-04390489 , version 1 (12-01-2024)
  • HAL Id : hal-04390489 , version 1
Anna Calissano, Théodore Papadopoulo, Xavier Pennec, Samuel Deslauriers-Gauthier. Graph Matching improves the Similarity of Structural Brain Networks. OHBM 2023 - Organization for Human Brain Mapping, Jul 2023, Montreal (Canada), Canada. ⟨hal-04390489⟩
13 Consultations
8 Téléchargements
