Homogeneity-Based Control Strategy for Trajectory Tracking in Perturbed Unicycle Mobile Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Control Systems Technology Année : 2024
Héctor Ríos
Manuel Mera
Gang Zheng
Alejandro Dzul
This paper deals with the tracking problem for the Unicycle Mobile Robot (UMR) with slippage effects. A homogeneous controller is developed based on a particular cascade control strategy. The robustness of the closed-loop system is studied. The design is essentially based on the canonical homogeneous norm being a Lyapunov function of the system. The (finite-time or exponential) convergence rate of the homogeneous controller can be tuned by a proper selection of the so-called homogeneity degree. Some experimental results illustrate the performance of the proposed homogeneous control in the UMR QBot2 by Quanser.
Automatique
UMR_control_journal_revised__.pdf (1.92 Mo) Télécharger le fichier
hal-04390587 , version 1 (12-01-2024)
Yu Zhou, Héctor Ríos, Manuel Mera, Andrey Polyakov, Gang Zheng, et al.. Homogeneity-Based Control Strategy for Trajectory Tracking in Perturbed Unicycle Mobile Robots. IEEE Transactions on Control Systems Technology, 2024, 32 (1), pp.274-281. ⟨10.1109/TCST.2023.3300273⟩. ⟨hal-04390587⟩
47 Consultations
36 Téléchargements
