Lower bounds for the joint batching, routing and sequencing problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
orbel37abs.pdf (86.97 Ko) Télécharger le fichier
hal-04391089 , version 1 (12-01-2024)
  • HAL Id : hal-04391089 , version 1
Olivier Briant, Hadrien Cambazard, Nicolas Catusse, Diego Cattaruzza, Maxime Ogier, et al.. Lower bounds for the joint batching, routing and sequencing problem. 37th annual conference of the Belgian Operational Research Society (ORBEL37), May 2023, Liège, Belgium. ⟨hal-04391089⟩
21 Consultations
11 Téléchargements
