A column generation approach to solve the Joint Order Batching and Picker Routing Problem including picker congestion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract_ORBEL23_PTorrealbaV1 (1).pdf (157.89 Ko) Télécharger le fichier
hal-04391684 , version 1 (12-01-2024)
  • HAL Id : hal-04391684 , version 1
Pablo Torrealba-González, Maxime Ogier, Frédéric Semet, Dominique Feillet. A column generation approach to solve the Joint Order Batching and Picker Routing Problem including picker congestion. 37th annual conference of the Belgian Operational Research Society (ORBEL 37), May 2023, Liège, Belgium. ⟨hal-04391684⟩
8 Consultations
9 Téléchargements
