A Nonlinear Elliptic Equation with a Degenerate Diffusion and a Source Term in L 1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
We study a simplified equation governing turbulent kinetic energy in a bounded domain, arising from turbulence modeling where the eddy diffusion is given by ρ(x)+ε, with ρ representing the Prandtl mixing length of the order of the distance to the boundary, and a right-hand side in L 1. We establish the convergence toward the formal limit equation as ε approaches 0, within fractional Sobolev spaces W 1/2,q .
TKE_eta_1.pdf (249.68 Ko) Télécharger le fichier
hal-04392244 , version 1 (13-01-2024)
hal-04392244 , version 2 (22-01-2024)
  • HAL Id : hal-04392244 , version 1
Guillaume Leloup, Roger Lewandowski. A Nonlinear Elliptic Equation with a Degenerate Diffusion and a Source Term in L 1. 2024. ⟨hal-04392244v1⟩
Collections
IRMAR-MECA
74 Consultations
22 Téléchargements
