Magnetic control of WEST plasmas through deep reinforcement learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Tokamaks require magnetic control across a wide range of plasma scenarios. The coupled behavior of plasma dynamics makes deep learning a suitable candidate for efficient control in order to fulfil these high-dimensional and non-linear situations. For example, on TCV, deep reinforcement learning has already been used for tracking of the plasma's magnetic equilibrium [1]. In this work, we apply such methods to the WEST tokamak, to address control of the plasma's shape, position, and current, in several relevant configurations. To this end, we developed a distributed framework to train an actorcritic agent on a C++ free boundary equilibrium code called NICE, in which resistive diffusion allows a more representative evolution of current profile throughout the simulation. The interface between components was done through UDS protocols for fast, asynchronous and reliable communication. The implemented tool handles feedback control of quantities of interest, with results showing flexibility of the method regarding the use of different training environments.
2023-SOFE-Samy-IEEE-TPS-v2.pdf (1.3 Mo) Télécharger le fichier
hal-04393963 , version 1 (15-01-2024)
hal-04393963 , version 2 (29-01-2024)
  • HAL Id : hal-04393963 , version 2
S Kerboua-Benlarbi, R Nouailletas, Blaise Faugeras, E Nardon, P Moreau. Magnetic control of WEST plasmas through deep reinforcement learning. 2023. ⟨hal-04393963v2⟩
113 Consultations
72 Téléchargements
