Genetic algorithms for force polytopes prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Knowledge of human’s force capacities enables the design of physical Human-Robot Interaction (pHRI) workspaces. As measuring force capacities for all postures is time consuming, predicting force capacities from a subset of measurements performed in a limited number of postures is crucial. The force capacities can be described as a convex polytope by means of a personalized musculoskeletal (MSK) model (Skuric et al. 2022). However, the tuning of a MSK model is difficult due to the high number of parameters. Thanks to its constraint-free nature on the optimization function, a genetic algorithm is implemented to find a MSK model parameter set, which fits and predicts force polytopes.
Résumé SB 2023 Gautier Laisné REVISED.pdf (272.79 Ko) Télécharger le fichier
hal-04396514 , version 1 (04-07-2023)
hal-04396514 , version 2 (16-01-2024)
Paternité
Gautier Laisné, Jean-Marc Salotti, Nasser Rezzoug. Genetic algorithms for force polytopes prediction. 48ème Congrès de la Société de Biomécanique, Société de Biomécanique, Oct 2023, Grenoble, France. pp.218, ⟨10.1080/10255842.2023.2246304⟩. ⟨hal-04396514v1⟩
127 Consultations
51 Téléchargements
